Sanibest Pump System - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2010, 07:00 AM   #1
sanibest pump system
I'm installing a below grade bath using the sanibest system to pump up the my sewer line, the instructions recommend using only a 3/4" discharge pipe diameter with "soft" 90's, meaning 2-45 put together, it seems small, has anyone installed this before using this size pipe?
vtboy51 is offline   Reply With Quote
Old 02-24-2010, 08:04 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... I donno That particular system, But, if it's a macerator type, 3/4" is probably plenty big enough...
Need plumbing system from Soviet Era mats. MDarg Plumbing 2 10-30-2009 10:23 PM
new system install.....questions firedogut HVAC 4 10-04-2009 07:10 PM
Sump pump drainage question famdog Plumbing 1 01-05-2009 01:42 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 10:42 PM
