Old 11-06-2011, 01:28 AM   #1
Sandy water plugged toilets and sinks
Water is not running in bathroom sinks and toilets. When it came out of the bathtub, it's full of sand. Seems like sand got into water lines running into the house. I ran the bathtub until the water was clear but how do I get bathroom sinks to run?
Felix520 is offline   Reply With Quote
Old 11-06-2011, 07:17 AM   #2
biggles's Avatar
fill a 5 gallon bucket and keep dumping it into the toilet then do the toilet tank a couple of times pull all the screens and let it run...are you on city water or well
Old 11-06-2011, 10:33 AM   #3
Plumb or Die!
Clean aerator screens on faucets
plumber666 is offline   Reply With Quote
Old 11-06-2011, 10:37 AM   #4
Super Moderator
Open up the outside hose bibs and flush out the pipe until that water runs clear before you run a lot of water through the toilets and sinks.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
sounds like running water nickandlisa09 Plumbing 4 06-20-2011 01:11 PM
Shutting of running water make toilets run pete0403 Plumbing 7 01-13-2011 12:07 AM
recent basement work and discolored water downers Plumbing 2 04-10-2009 06:30 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
