Sand Fill Up My Sump Pump Crock - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2010, 04:45 PM   #1
Sand fill up my sump pump crock
This week end to my surprise there was 3 buckets of sand in my sump pump crock, need less to say it disabled the pump. This has never happened before . the house is aprox 10 years old. I have been checking everyday now there is a just a little sand in the bottom. Any ideas what could have happened and should I keep worrying it's going to happen again?
jcgrays is offline   Reply With Quote
Old 06-28-2010, 05:05 PM   #2
Rewards Points: 1,448
A section of the ground around the house may have collapsed causing sand to enter the perimeter drain pipes and make its way to the crock. Can you tell if there is sand collected in one of the pipes leading into the crock?
Usually the perforated drain pipes are wrapped in porous fabric to minimize sand getting in.
AllanJ is online now   Reply With Quote
Old 06-29-2010, 12:27 PM   #3
sand in the sump pump
I have not checked around the house for signs that the ground had colapsed, I will look today. The only visible drains I can see are the drains in the basemant widow wells. I well check them as well. Coming into the Crock there is just one big pipe and water tricles all the time. So far just a little bit of sand remains in the crock and seems to be the same amount each day.I will shop vac that sand out and see if I get any new Sand.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 07:14 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
