Sand In Basement Pump- Well Room - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2011, 05:06 PM   #1
Sand in basement pump- well room
How did sand get in the basement pump-well room? Is something wrong with the pump or the well? We have noticed the pump is running but we have not used the water and nothing is running in the house.
bsvans is offline   Reply With Quote
Old 02-10-2011, 05:10 PM   #2
Experienced
Jackofall1's Avatar
Are you talking about a sump pump or a well pump?
Edit- Its not unusual to have sand or silt in a sump well, it is carried in with the water.
Sand on the other hand from a well is a good indication that the well is running dry.
Mark
Small basement room moisture ? timrec Building & Construction 2 08-25-2010 06:14 AM
Adding a basement bathroom with sewage ejector pump qoncept Plumbing 5 07-13-2010 10:48 AM
Insulate storage room in basement bkeech Building & Construction 2 03-11-2010 11:31 AM
Cold Room in Finished Basement Creekbender Building & Construction 4 01-31-2010 09:54 AM
Constructing a walkout basement mud room DIY Hack Building & Construction 2 01-21-2010 07:21 PM
