Salty Water? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 04:26 PM   #16
Rewards Points: 99
Wow thanx guys. So do I have to call someone to replace the media? If so,how much would it cost and could I do it myself?
panteramatt is offline   Reply With Quote
Old 01-28-2012, 11:49 AM   #17
I have a roof, how long will it take? I need surgery, what are my chances? I have a water system, what will it cost to fix?
Sorry, but as we have mentioned before, it is absolutely impossible to recommend a solution (let alone costs) without knowing what you have, what needs to be done and how willing you are to do it. Do you have at least pictures of the system?
The tank after the softener is probably carbon as most pH tanks go before the softener---but there is no telling until more information is provided, and that may take dismantling the system and examining it.
Whether or not you can doit yourself depends on your aptitude for DIY projects. Some particular tools may be needed but all-in-all, most handyman types can rebed units.
Andy Christensen
Andy CWS is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Culligan Mark 89, water SALTY after regen. Lehouillier Plumbing 11 04-11-2010 07:47 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
