-   -   safely cut galvanized pipe (http://www.diychatroom.com/f7/safely-cut-galvanized-pipe-157037/)
texancowboy 09-17-2012 12:15 AM
hey guys. as yall may know, i am in the process of some renovation. one of the main things im doing is remodeling my bathroom. but, before i do anything, i wanna remove the old galvanized pipe and go with pex or pvc (probably pex). However, I do not have enough money to do a total repipe, therefore, I simply plan of replacing the lines above the floor and tiing into the old galvanized underneath. however, i have been told that when you cut galvanized pipe, its very likly to cause ruptures elsewhere. any advice on how to avoid this? i was thinking maybe using a hack saw and going really slowly...
jaydevries 09-17-2012 12:28 AM
if you do that then you will have to re thread pipe. i would cut pipe 12 inches from a joint and then unthread and then thread a pex fitting in and run from there
texancowboy 09-17-2012 12:39 AM
but can it safely be cut without rupturing other places?
jaydevries 09-17-2012 12:47 AM
i have had a 99.9 percent rate of being able to do it with out a leak using fine tooth sawzall blade
joed 09-17-2012 08:01 AM
Can it be cut without rupturing elsewhere? Probably, but it depends how bad the pipe is. If it is rusted and ready to bust then probably not. If it is still in good condition then probably not problem. A hand hack saw will probably be less likely to damage than a sawsall.
joecaption 09-17-2012 08:07 AM
You do know that PVC is only used in drain lines never supplys right?
Supplys should only be Pex, CPVC, or copper.
Also you do know all your main lines need to be run with 3/4" then tee off 1/2 to the supplys.
DannyT 09-17-2012 08:45 AM
you can always unscrew it. use 2 wrenches if you do so you don't stress the joints you are leaving.
rjniles 09-17-2012 09:36 AM
Not totally true, PVC can be used for cold water supplies. Commonly PVC is used for the service from the meter to the house. At least commonly in my area.
Can be used in the house also but I don't recommend it.
My wife rents a building where all the cold water is PVC and the hot is CPVC. Stupid but that what was done.
texancowboy 09-17-2012 10:56 AM
Yeah, I know
The pipe im cutting is 3/4 galvanized, but it is directly under the backroom (furthest fixtures from the meter). I'm thinking about cuttin it with a hacksaw, tiling on with a 3/4 1/2 union, then then runnin 1/2 oex to my toilet, shower, and sink. thoughts?
texancowboy 09-17-2012 10:57 AM
the pipe, for the most part, appears to be in good shape.
DannyT 09-17-2012 11:50 AM
i had to cut numerous galvanized lines in fla while doing remodeling. i learned quickly that you don't use a new metal blade. it grabs the pipe and shakes the crap out of it. old used blades cut slower but don't shake the pipe. if you cut out the 3/4 don't replace it with 1/2 inch, use 3/4.
