Is It Safe To Take Heat Gun To 3/4" PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 11:12 AM   #1
Rewards Points: 1,062
Question
is it safe to take heat gun to 3/4" PVC pipe
i have a frost hydrant in my shed, from there there is 3/4" PVC pipe to an outside spigot to which a hose is attached. even though the hydrant was turned off and i do have a leakout system for leftover water in the pipe, some water drained back from the hose and into the pipe and froze there. the spigot valve is blocked frozen.
i wonder if it is safe to take heat gun to the PVC pipe as i really need to use the hose (and don't care if it freezes again after i do). my concern is that i might deform the pipe or melt the fittings.
thanks
Old 01-24-2013, 11:52 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,.... I'd try it,....
Open the valve, so there's pressure pushin' the ice out, 'n don't just leave the heater blowin' on it, but stay with it, 'n pay attention to what it's doin'...
The Following User Says Thank You to Bondo For This Useful Post:
amakarevic (01-24-2013)
Old 01-24-2013, 12:13 PM   #3
Rewards Points: 340
yeah, be careful. keep a good distance, low temperature setting and don't use a nozzle that focuses the heat. it is extremely easy to soften and bend pvc pipe with a heat gun.
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
Old 01-24-2013, 12:16 PM   #4
Rewards Points: 6,652
It would probably be easier to just put heat tape on it, and let the tape warm it up slowly over time, vs. having to stand there for hours to use the heat gun. Even placing a heater in the shed, should be enough over time to warm it up to melt the ice inside the pipe.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
amakarevic (01-24-2013), Hardway (01-24-2013)
Old 01-24-2013, 02:51 PM   #5
joed's Avatar
Rewards Points: 13,696
Pour hot water from the kitchen tap over it. I use my plant watering can. Usually works with about half the can to thaw the spigot.
Old 01-24-2013, 08:04 PM   #6
regular pvc will blow apart at around 110 degrees
Old 01-24-2013, 08:27 PM   #7
funfool's Avatar
Rewards Points: 534
I would be skeered to try a heat gun, they get hot, maybe a hair dryer, or as others suggested, stick a heater in the shed for a couple hours.
Not sure if this is important, I was told by our plumber, that if you leave a hose connected to a frost free hose bib, they will freeze, they can not work as they are designed to.
In this case, actually burst in the wall and caused some drywall damage.
I imagine your hydrant works with the same principle, when you get it thawed and done with the hose, disconnect it and may not have the problem again.
funfool is offline   Reply With Quote
Tags
frost
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Snap cutter not safe on old cast iron pipe? darsunt Plumbing 3 11-07-2012 05:54 PM
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
