Saddle Tap On Pex Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2009, 04:02 PM   #1
saddle tap on Pex line
My home was inspected (I'm selling it) and the inspector questioned a saddle
tap that an HVAC installer had put on a pex line to hook up a humidifier a year after the house was built. What is the proper way to hook up the line under typical plumbing codes?
mainstreetprod is offline   Reply With Quote
Old 01-30-2009, 04:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,.. I'd have just Cut it,+ used a "T" fitting....
Old 01-31-2009, 01:13 AM   #3
Saddle taps are really good, fast and make it easy to hook water up. If it isn't leaking I would leave it alone.
John McCabe is offline   Reply With Quote
Old 01-31-2009, 07:11 AM   #4
what the HVAC guy used is the norm but i never heard of using a saddle valve on PEX. Wonder if that is legit? Not leaking huh? Learn something new everyday
II Weeks is offline   Reply With Quote
Old 01-31-2009, 07:14 AM   #5
Remodeling Contractor
A PEX ice maker kit would have a Tee fitting with a shutoff built in. If you do not like the saddle you could use this. Just pushes onto the PEX, no tools required. but the saddle valve if not leaking is fine.
Old 01-31-2009, 10:14 AM   #6
I' never seen a saddle tap used on pex, even though its not leaking it may be doomed with failure in the future, I would replace with tee immedietly. It may be the hvac guy didn't have any crimping tools and was only used to connecting to copper.
zosoplumber is offline   Reply With Quote
Water supply line replacement bamaknox Plumbing 2 01-08-2009 09:51 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
