Sacrificial Anode Replacement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2010, 09:14 AM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Sacrificial anode replacement.
Trying to replace the sacrificial anode on my 6 gallon propane RV water heater. It has a standard 1 - 1/16 inch hex nut like a standard home water heater. Cannot budge it; tried WD-40 and a pipe extension- no luck. This is a 20+ year old unit and I doubt the anode has ever been replaced. Anyone have any tricks to get these things out?
Coastal South Carolina
Old 02-22-2010, 06:57 PM   #2
just a cheater bar. but if it's already 20 years old it would be a good idea to just replace it.
plumber Jim is offline   Reply With Quote
Old 02-23-2010, 01:02 PM   #3
Rewards Points: 346
Careful using a cheater... Those tanks are not very strong and you may tear the wall if you turn it too hard. I used a 3/8 impact on my 2003 Wildcat and after a few minutes alternating between loosening and tightening it came off. I put some lithium grease on it when I put it back on.
RegeSullivan is online now   Reply With Quote
Old 02-27-2010, 06:05 PM   #4
I dont know what kind of magic they use on those things but like the guys said a big breaker bar or a small piece of det cord and a few grunts. Good luck and why are you replaceing it ?
arcticbouncer is offline   Reply With Quote
Sign of deteriorating water heater anode? Frank O Plumbing 18 02-28-2010 01:52 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
Bradford White sacrificial anode replacement problem vinnie1 Plumbing 3 07-27-2009 09:01 PM
Teflon tape or pipe dope an anode rod? Nestor_Kelebay Plumbing 4 02-08-2009 11:42 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
