'S' Traps - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2012, 09:16 PM   #1
'S' traps
A day late and a dollar short, but I'm just discovering that 'S' traps are not the going thing.
For work already done that's committed to 'S' traps, if the vent line taps off on a reverse running 'T' just below the trap, any reason to believe that it won't work just fine? Right now, it's only one bathroom that would include a sink and shower with this design. The second bathroom follows, and obviously I'll have to do my homework better on that one.
As usual, any help is greatly appreciated.
David
lynxpilot is offline   Reply With Quote
Old 10-08-2012, 06:19 AM   #2
Rewards Points: 3,130
I see you're in Missouri, so probably don't have any building or plumbing codes to worry about. While S traps have not been legal for a long time, that does't mean they don't work. Try your setup for a while. If it works, fine. If it doesn't, tear it out and use P traps.
Old 10-08-2012, 10:10 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
S traps will siphon it self dry thus breaking the water seal.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 10-09-2012, 04:40 AM   #4
If the last part of the S trap (the part going down into the floor) is larger than the trap than there is less of a chance of getting a vacuum and causing a siphon on the trap. 2 drain pipe with 1.5 S trap.
I have seen a few times where someone put a 8 section of 2 pipe against the S trap to help eliminate the siphon and worked part of the time.
1950home is offline   Reply With Quote
chipmunks, best traps D270 Pest Control 8 07-04-2012 11:59 AM
NO Traps in Basement Floor Drains IrwinRedtail Plumbing 3 02-04-2012 05:22 PM
No Heat: Pressure switch & Hoses forming traps Yooperman906 HVAC 22 01-04-2011 09:52 AM
water heater heat traps BlueBSH Plumbing 6 10-22-2010 05:06 PM
plumbing j traps under the sink baby12121 Plumbing 1 10-17-2010 03:45 PM
