S-Trap To Horizontal Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2012, 08:40 AM   #1
Rewards Points: 165
S-Trap to horizontal drain
I just had a new kitchen sink installed and the drain in the sink basin is offset to the left of the drain line coming out of the wall. The drain line coming out of the wall comes out horizontally for about 12 to 16 inches, then there is an s-trap to the sink drain tail piece. So far this setup seems to be working, but are there any issues (code, or potential syphoning). I know that syphoning can occur when an s-trap goes into a vertical drain, but does that still occur if it drains into a horizontal line?
chronojosh is online now   Reply With Quote
Old 08-17-2012, 09:01 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Need a picture. If it goes into a horizontal trap arm it is not a S trap.
Coastal South Carolina
Old 08-17-2012, 09:01 AM   #3
if the drain line comes out of the wall it should be hookde up with a p-trap. i don't know how you could hook an s-trap to a drain coming out of the wall.
Old 08-17-2012, 09:58 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
S-trap + P-trap.
Journeyman Plumber
Old 08-17-2012, 11:53 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
If someone put a 90 looking up at the end of the trap arm- stuck an s trap on it to the sink tailpiece.....
S traps are a nono.
I'd like to see a picture of what you have.
Can you lengthen the sink tailpiece so a normal p trap will connect to the trap arm? (may need a horizontal offset to get it to line up to the drain)
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 10:13 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
should I replace the drain and P trap jameshow Plumbing 2 04-26-2009 10:32 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
