Old 01-17-2011, 08:04 PM   #1
S trap in basement shower?
Hello:
I have a rough in for a shower which is right beside the main stack in our basement. The question I have is do I need an s trap? Or can I install a shower directly into it?
Rob
Rlly001 is offline   Reply With Quote
Old 01-17-2011, 08:14 PM   #2
Originally Posted by Rlly001 View Post
Hello:
Rob
You have to pour water down that pipe and with a flashlight confirm that a part of the water stays there, if the water goes straight thru that means you don't have a trap below the floor, you MUST have a trap below the floor, you CANNOT hook up a shower without one!
braindead is offline   Reply With Quote
Old 01-17-2011, 08:48 PM   #3
You need a trap between your new shower and the DWV stack. S-traps are to be avoided, and in many (all?) cases are illegal except in the case of grandfathered replacements. A coorect application would use a p-trap.
The trap should be correctly vented also, to "protect" the trap
Anti-wingnut is offline   Reply With Quote
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 01:16 PM
Basement Shower in place of tub Georgew Plumbing 4 01-13-2010 07:20 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Basement Shower Drain Relocation rmdhokie Plumbing 1 07-01-2008 11:17 PM
