"S" Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2008, 07:02 PM   #1
"S" trap
Is syphon the only problem with using "S" traps?
BillyD is offline   Reply With Quote
Old 06-06-2008, 07:40 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yep, no one likes the smell of sewer gases.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-06-2008, 09:50 PM   #3
Registered User
Termite's Avatar
I don't like seeing them. Sewer gas is definately the issue. That type of trap setup has the potential of sucking just enough water out of the trap to allow sewer gas to pass. This is a common setup, and problem, with clothes washing machine drains. The water velocity and volume only works against the trap, and increases the possibility of it siphoning itself "dry".
For a 2" drain, you're supposed to have a 4" section of horizontal pipe between the trap and the downstream vertical run. 1-1/2" would require 3", and so on.
Old 06-07-2008, 02:53 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Now that you bring that up, i'd like to hear exactly how YOU would measure said 4" section, because technically, if you put a 2" p-trap, and a 2x1-1/2x2 sanitary tee hub-to-hub, there is 4 inches between the vent and the trap weir, making it impossible to have too short of a horizontal piece anyway.
This is often a subject of debate at school.
Journeyman Plumber
Old 06-07-2008, 07:26 PM   #5
Registered User
Termite's Avatar
Alan,
Putting them hub to hub is the problem in my opinion. So, I'd require a 4" nipple or section of PVC between the two hubs horizontally, on 2" pipe. I'm not measuring wier to wier. The inherent "s" shape is what should be avoided, especially at the clothes washer, which discharges with great velocity and volume.
This is definately a subject with a lot of debate and opinions vary.
Goodman - pressure switch/condensate trap jrmac HVAC 4 09-07-2009 05:49 AM
Older sewer w/ backwards trap Gregad Plumbing 4 08-21-2007 09:12 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 07:06 PM
