S Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2008, 08:31 PM   #1
Rewards Points: 45
P Trap
I'm replacing my bathroom petalstool sink. I removed the sink from the wall and water lines. I left part of the "P" trap in place (the down spout). My wife ran the washer machine and water came out when the washer went to it's rinse cycle. Is this normal? Should I have left the the "P" trap on?
My home is on a slab and the washer is on the same floor.
tate16t is offline   Reply With Quote
Old 03-29-2008, 09:03 PM   #2
Send a message via AIM to Marlin
No it isn't normal. That means the water draining from the washer is filling the DVW system up to at least the point of that P trap. Probably a partially stopped or undersized line. Could be the waste for the washer is incorrectly piped as well.
Marlin is offline   Reply With Quote
Old 03-29-2008, 09:20 PM   #3
Rewards Points: 45
Thanks. It's probably stopped as I have had stopped problems before.
Goodman - pressure switch/condensate trap jrmac HVAC 4 09-07-2009 04:49 AM
Older sewer w/ backwards trap Gregad Plumbing 4 08-21-2007 08:12 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 06:06 PM
