#1 |
S to P trap convert
in an old house where drains go thru floor is this conversion a good way to go ?
#2 |
Super Moderator
S to P trap convert
Both pictures are S traps--Add a T where the right hand 90 now sits--install an AAV to the top --then you will have a P-trap
Air Admittance Valves are not code in some areas--so check first.
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
S to P trap convert
so like this?
#4 |
Super Moderator
S to P trap convert
Good!! There you have it----
| The Following User Says Thank You to oh'mike For This Useful Post: | petros151 (07-04-2012) |
#5 |
S to P trap convert
ok thanks, this looks simple to do!
#6 |
sacramento plumber
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
S to P trap convert
to add to petros151 30" max
#7 |
S to P trap convert |
#8 |
A "Handy Husband"
S to P trap convert
The AAV should be higher than the stand pipe.
#9 |
S to P trap convert
sorry newbie here. Higher than what part of this diagram....
I am putting this under the sink in a sink base cab. I cannot put things in the walls. So the sink base is up against the wall and the highest I can go with an AAV is at the top of the cab. so that would make it a bit higher than the level at which the sink connects to the drain. I have an illustration to show what I would do (have not done it yet but HOPE to do this TOMORROW) THANKS !!! |
#10 |
A "Handy Husband"
S to P trap convert
Your earlier posts showed a laundry standpipe not a sink. The AAV is supposed to be above the flood rim of the sink.
#11 |
sacramento plumber
S to P trap convert
2"drain would be nice
#12 |
A "Handy Husband"
S to P trap convert
For a laundry standpipe- yes. For a sink 1.5" is fine.
#13 | |
S to P trap convertQuote:
as to the AAV In my case the base cab is up against the wall and as of now there is no where to put the AAV except at the top of the cab which is below the flood rim. so in this case is it worthless to try an AAV at all? and this another issue-- I am going to have a Dish washer drain into the same drain as the sink. here is another drawing... gulp
#14 |
Bill Kearney
S to P trap convert
When the AAV is lower than the flood rim of the sink then water will overflow through it first, leading to a leak you won't seek at the sink first.
| Display Modes | |
| Furnace condensate drain/trap issue | SteveC | HVAC | 33 | 12-27-2012 12:46 PM |
| Would this be a 'P' trap or an illegal 'S' trap? | klondiker | Plumbing | 7 | 04-06-2012 11:18 PM |
| Trane XR90 - Condensate Drane Trap | JDWorks | HVAC | 16 | 02-07-2012 08:59 PM |
| kitchen wall drain outlet higher than trap arm | Druidia | Plumbing | 24 | 10-13-2011 01:39 PM |
| Cat trap fever | radtek | General Discussion | 13 | 05-31-2009 07:18 PM |
