Old 05-22-2012, 11:30 AM   #1
RV Plumbing
The piping in my RV looks like Schedule 40 CPVC but appears to be much thinner-walled. Is it something unique to RVs? I have heard of thinwall (Schedule 30) pipe but have never seen any. Are fittings available to connect the thin stuff to "regular" CPVC?
Old 05-23-2012, 01:00 AM   #2
Persona Non Grata
VIPlumber's Avatar
RV Plumbing
I believe that the pipe schedules go 20, 40, 80 & 120. That being said your best bet for the part(s) you're looking for are either a plumbing supply store or an RV dealer who has a service depot.
VIPlumber is offline   Reply With Quote
Old 05-23-2012, 07:24 AM   #3
RV Plumbing
Could it be PEX???
COLDIRON is offline   Reply With Quote
Old 05-23-2012, 07:41 AM   #4
RV Plumbing
That was my thought, if it's an older model it would be Quest, which would be gray, newer ones use Pex.
It should say right on the pipe what it is.
Old 05-24-2012, 12:22 PM   #5
RV Plumbing
It's not PEX. It's too rigid and the joints are glued. The RV is a 2010 model. I don't remember seeing any markings on the pipe but will check.
Old 05-24-2012, 03:17 PM   #6
RV Plumbing
Sounds like an old rig.
Old 05-26-2012, 10:25 AM   #7
RV Plumbing
VIPlumber, you forgot Schedule 5 pipe.
Much of the RV plumbing is special to the RV business. Just go to an RV repair shop. Take samples.
fireguy is offline   Reply With Quote
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to find plumbing distributors for plumbing invention? Timster Plumbing 7 05-20-2009 02:53 AM
