RUUD Powervent Water Heater Not Always Lighting - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2010, 06:47 AM   #1
RUUD powervent water heater not always lighting
I have a RUUD Powervent Model PVP50E-1 A that has been intermittently not lighting. I can hear the powervent/blower running and running (more than it should) but the burner (natural gas) does not always light and, by the time I get down there it is not even trying (spark not firing). I turn it off then back on and I can hear something click, the spark kicks in and then it lights. I would guess it is a relay clicking and going bad. Anyone had this problem? thanks
bloom42 is offline   Reply With Quote
Old 11-17-2014, 12:15 AM   #2
Rewards Points: 4
Question
I have same problem...resolution?
Hi Bloom42,
Here in November of 2014 I have the same water heater and exactly the same problem you have described. I am wondering how you resolved it as I didn't see any replies to your post. I'm hoping it is a simple part replacement (thermostat, thermocouple, etc) that I can do myself or if a plumber is necessary.
Thanks, BigAl1954
BigAl1954 is offline   Reply With Quote
Old 11-17-2014, 09:35 AM   #3
Rewards Points: 774
Welcome to my world....same problem, same or similar model. We are on LP, but based on what I have read and had people comment on my thread, it sounds like a gas valve issue. Gas valves for your WH are not cheap. I am having someone look at it today to give me an estimate.
Power Vent Water Heater Issues
cibula11 is offline   Reply With Quote
Old 10-05-2015, 02:15 PM   #4
Rewards Points: 4
Any luck on solving your water heater problem?
I took the burner assembly out, cleaned the igniter, and it seemed to have solved the problem until today, when our water was cold again. The power vent fan was running. I turned off the power for a few seconds, then back on again. The electronic unit was flashing and I could hear sparking, and then it ignited and now water is hot again. This happens intermittently and is not too much of a problem to re-start as opposed to a very expensive repair. Plus, the tank is nearly 14 yrs. old so I don't want to pay for an expensive repair. Was hoping there might be an easy fix. I would be willing to buy a new electronic module and install myself if that is the problem, but don't want to tackle a gas valve or thermostat.
Just wondering how you solved your similar issue?
Thanks, Al
Old 10-06-2015, 04:14 PM   #5
Rewards Points: 20
Power vent water heaters have a life expectancy of 6 years. Congratulations on getting twice the expected life out of your's! If you have problems again, DO NOT repair, replace instead. Your water heater is living on bonus time.
SHR Plumber is offline   Reply With Quote
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 10:57 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
