Rusty Water Coming From Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2009, 03:32 PM   #1
Rusty water coming from shower
We have a rental unit and when you turn the shower on, the water is a rusty color for about 7 seconds. What could this be from? They are doing work way down the road, but they haven't shut the water off. HELP!!!
Eric in Key Wes is offline   Reply With Quote
Old 07-09-2009, 05:05 PM   #2
biggles's Avatar
if it is on both hot and cold it is the city banging the pipes down the street,if it is only the hot water ...might want to flush the hot water heater
Old 07-09-2009, 06:25 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
The piping from the shower valve to the down spout is more than likely causing the problem. Check to see if the pipe is galv or steel instead of brass or copper.
Old 07-10-2009, 11:15 AM   #4
Thanks everyone. It was the galvanized nipple that goes from the tub spout to the water line. Thanks again!!
steps for water proofing shower rvattyam Tiling, ceramics, marble 2 06-18-2009 10:38 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Are shower water problems caused by old pipes? bathroom nightmare Plumbing 17 02-02-2008 10:39 PM
