Old 06-06-2007, 10:26 PM   #1
Rusty Water
Good evening. We have an older home and a bathtub and a couple sinks that are not frequently used. When we go to turn the water on - out comes rusty colored water. Anyway to stop this without replacing the pipes?
Sarge is offline   Reply With Quote
Old 06-06-2007, 10:31 PM   #2
That one Guy's Avatar
Rusty Water
I suspect you have galvanized water lines?
They will make the water like that if they sit for awhile unused.
That one Guy is offline   Reply With Quote
Old 06-06-2007, 10:36 PM   #3
weekend warrior
Rusty Water
do you have public/well water?
johnny331 is offline   Reply With Quote
Old 06-07-2007, 08:24 AM   #4
Rusty Water
Yep, there is a bunch of galvanized still left.
Old 06-07-2007, 09:49 AM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Rusty Water
Replace the pipes.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
More On This Topic
The last part of creating your home renovation plan is to create a master plan of all the tasks that need to be done. Create a plan that has the order in which the construction will be done, and within each category, for example electric, plumbing, walls... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
This area used to be a back porch where the ceiling drops down. This entire area was a back porch. This end segment of it was a laundry room. When we decided to make this an entry alcove, what we did was we had to end the plumbing here, we had to... Read More »
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
