Rusty Stubborn Garbage Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2014, 10:42 PM   #1
Rusty stubborn garbage disposal
I have been trying to remove this garbage disposal for a month. It is completely rusted and stuck. I was able to loosen (remove) the 3 sink flange bolts, but I cannot locate the snap ring. I have tried ..allen wrenches...screwdrivers...prybars.... absolutely nothing will work, please help! P.s. I am going back to a regular drain when I am finished!!!
Rusty stubborn garbage disposal-img_20140311_193155.jpg   Rusty stubborn garbage disposal-img_20140311_193212.jpg   Rusty stubborn garbage disposal-img_20140311_193224.jpg   Rusty stubborn garbage disposal-img_20140311_221811.jpg   Rusty stubborn garbage disposal-img_20140311_221828.jpg
scm60s is offline   Reply With Quote
Old 03-11-2014, 10:54 PM   #2
Rewards Points: 30
I can see the snap ring in your picture. It is under the triangular ring the 3 bolts used to be in. The really rusty ring has to be turned to the left and the disposal will fall to the bottom of your cabinet, allowing you to raise the triangular ring to access the snap ring. Utilize one of the three small round leverage holes, like the one right on the front, to turn the rusty ring. Even that rusty, you should be able to drop the disposal within 3 minutes.
SHR Plumber is offline   Reply With Quote
Old 03-11-2014, 10:57 PM   #3
I nhave read everything I can get my hands on, I am missing something!
Old 03-12-2014, 12:16 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 904
See the attached image-
Once the disposal is dropped you'll see the snap ring
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
oh'mike (03-12-2014), plummen (03-14-2014), SHR Plumber (03-12-2014)
Old 03-12-2014, 02:42 AM   #5
Rewards Points: 6,652
If it was me. I would just pull the whole sink and then just put in a new sink, faucet and disposal.
Can you get a hacksaw blade up there and just cut off the fitting underneath, or maybe lift it and cut it right below the flange?
Try seeing if you can push up on it, then cut off the flange on the drain fitting for it, where it sits in the sink. Or if you can, cut the bolts, then turn to cut the other one or two, and that should allow you to separate the two sections, so you can remove.
Old 03-12-2014, 08:25 AM   #6
Do what E said, no need to cut anything. Put the screws back in and tighten them up first to keep the whole drain assembly from spinning. Then insert the shank of the screwdriver into one of the curled tabs on the lock ring (as shown in E's picture) and turn the ring counter-clockwise. That'll drop the disposal out of the way and reveal the snap ring. Step two is to remove those three screws (again) and THEN pry out the snap ring.
Ishmael is offline   Reply With Quote
Old 03-12-2014, 10:24 AM   #7
I failed to mention that I have attempted to turn the garbage disposal with every tool I could find. IT WILL NOT BUDGE! Not with screwdrivers, allen wrenches, hammer, etc... and yes the screws were not unscrewed at the time!
Old 03-12-2014, 10:35 AM   #8
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
WD-40 around the ring. let sit for a bit. lightly tap the ring with hammer, WD-40 again. Using the longest screwdriver that will fit attempt to remove lock ring.
gmaint is offline   Reply With Quote
The Following User Says Thank You to gmaint For This Useful Post:
Ishmael (03-12-2014)
Old 03-12-2014, 02:05 PM   #9
Owner
LateralConcepts's Avatar
Not trying to offend, but lefty loosey righty tighty. Are you sure you're trying to turn it the right direction? I've never encountered one I couldn't get off.
Have you tried an actual disposer removal tool?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
Old 03-12-2014, 06:29 PM   #10
Rewards Points: 2,108
Do you have a saw all. Use a metal blade and cut it out through the stainless steel flange above your disposal. Cut inbetween your sink bottom and the flat plate resting on your disposal. Wear safety glasses..
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 03-12-2014, 08:06 PM   #11
Originally Posted by Ghostmaker View Post
Do you have a saw all. Use a metal blade and cut it out through the stainless steel flange above your disposal. Cut in between your sink bottom and the flat plate resting on your disposal. Wear safety glasses..
Hey, wait. I said that. I see that I am not the only one that is thinking of taking the easy route.
Old 03-12-2014, 08:46 PM   #12
Rewards Points: 582
ok Iam pissed how do you do that ben sr
Old 03-12-2014, 09:25 PM   #13
Rewards Points: 30
You do not want to turn the disposal! Just the mounting ring. DO NOT turn the disposal. All that will do is...turn the disposal.
Old 03-12-2014, 09:28 PM   #14
Rewards Points: 30
There are a lot of good tips on this thread. Many of which should have made removing the disposal possible. Unfortunately, at this point if you have not been able to remove the disposal you will need to contact a licensed plumber to do it for you. I am sorry it did not work out for you this time.
Old 03-13-2014, 02:19 AM   #15
Rewards Points: 744
Careful there. Some people here get easily offended by our blunt, brutal honesty here.
Seattle2k is offline   Reply With Quote
Tags
garbage disposal , sink drain
Dishwasher and garbage disposal problems longislander2 Appliances 7 01-16-2014 10:11 PM
Having electrical trouble with my garbage disposal Bonavita513 Electrical 11 09-25-2012 07:09 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
