Rusted Toilet Flange Removal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2008, 10:22 AM   #1
Send a message via AIM to Boughamer Send a message via Yahoo to Boughamer
rusted toilet flange removal?
I bought a house over 30 years old. I replaced 2 toilets already, when I went to replace the 3rd one I found a rusted flange. While in the process of removing the bolts, I hit a pocket of rust. Well I started chipping the rust away, now the flange is only half a ring now. How do I replace it, it is on a cement slab. Any help would be appreciated!
Boughamer is offline   Reply With Quote
Old 07-06-2008, 12:37 PM   #2
You need a flange repair kit. I have included a link so you can see what is available and decide for your problem. Most of these can be purchased at HD or Lowes. Just click on the link below. You will also need tapcon screws since the parts need to be fastened to the concrete floor.
http://www.quickfixplumbingproducts.com/
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-06-2008, 01:53 PM   #3
Thanks for the help I went get the parts. I appreciate the help Thanks.
Old 07-06-2008, 05:54 PM   #4
Installed everything no leaks was succesful
Old 07-06-2008, 07:44 PM   #5
Glad it all came together for you and it solved the problem.
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 10:53 PM
Toilet Flange txbostont Plumbing 5 10-31-2007 12:01 PM
