Rusted Toilet Flange And Damaged Floor In Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2010, 02:45 PM   #1
Question
Rusted Toilet Flange and Damaged Floor in Basement Bathroom
Good Day - I'm replacing my toilet in my basement bathroom. When I removed it, the flange is rusted and unusable. Another thing is the flooring is damaged around it and cannot be used to anchor the the toilet (see depth of screw driver in hole). I removed the rusted areas of the flange, these are the areas where the toilet will be bolted to. I want to remove the entire piece but I'm concerned about damaging the actual waste pipe which is PVC. Any suggestions will be greatly appreciated. Thank you in advance.
Bronxy is offline   Reply With Quote
Old 08-07-2010, 05:47 PM   #2
Owner
LateralConcepts's Avatar
Unfortunately you're gonna need to jackhammer and replace the entire thing. You'll need to expose the pipe underneath (which appears to be a 90 degree elbow). That means you'll need to expose it back far enough to replace the 90, and install a new closet flange.
EDIT - If there's enough good cement under the old flange you might be able to install a quick flange with masonry screws.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-07-2010, 08:51 PM   #3
Actually, you can buy a steel flange adapter that would allow you to bolt it to the floor just outside your dimensions. Home Depot carries them.
Mike
Mike's Plumbing is offline   Reply With Quote
Old 08-07-2010, 10:01 PM   #4
Owner
Mike
It's called a "closet flange quick ring". Google it so you know what they look like. http://www.plumbsource.net/product/2...ment-Ring.html
Secure it with Tapcon masonry screws. The big blue ones.
Lateral
(208) 818-8241
Old 05-29-2011, 10:47 PM   #5
Closet flange quick ring installation
Hello; when installing a closet-flange-quick-ring over a corroded, broken flange, is there a need for caulking of any kind?
Or does the wax seal take care of any gaps.
Thank you,
- Leo
LKluger is offline   Reply With Quote
Old 05-30-2011, 12:29 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 904
Thank you,
- Leo
Yes, you should caulk it. Revisit the link. It references a type of caulk that will work.
Tags
replace , rusted , toilet flange
replacing toilet flange tomie Plumbing 2 05-28-2010 01:35 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 06:18 PM
Removing damaged bathroom subfloor icandoitmyself Flooring 3 10-23-2007 08:50 AM
