-   -   Rusted toilet flange (http://www.diychatroom.com/f7/rusted-toilet-flange-27352/)
Blondesense 09-25-2008 12:23 PM
I'm in the process of re-tiling our second bathroom. We pulled the toilet and found the flange rusted to the point one of the bolts won't hold.
I picked up a stainless steel repair ring, and since it looked a little low I also picked up a PVC extender.
If I use the repair ring it will end up right at or just below the tile. Would it be better to use it and maybe an extra wax ring or can I use the extension as a repair ring since it will bring it to a level just above the tile?
Or is there another solution without tearing up the pipe?
We are on a slab foundation and installing ceramic tile.
I'm heading off to work now, but I will check back later and can add a pic then if I need to.
JDC 09-25-2008 07:50 PM
I'd use the extension to bring it to the correct elevation. I hate hate hate hate hate hate....did I mention I dont like.....using more than one wax ring. I've seen one strand of wax cause a toilet to backup, overflow, flood the bathroom, leak into the ceiling below....needless to say it was a mess. Oh again....did I mention this was done at my house when I was a 2nd year apprentice? lol broke me of more than one wax ring. :thumbsup:
ltgarrett 09-26-2008 12:21 AM
There are extra thick wax rings that exist and recommended to use when rasing the floor height. Lowes carries the extra thick rings.
Blondesense 09-27-2008 11:48 AM
Thanks for your advice.
DUDE! 09-28-2008 12:58 PM
JDC is better at this then me, just my two cents, I don't care for the two rings but have done it before, sometimes you just gotto, anyway, last job I was at, commercial building, original install put the flange a tad too low in a slab, plumber came in and used the pvc extender, he said he doesn't care for them because it downsizes the inside diameter of the drain pipe, could lead to clogging. I guess I'd go with the extender, at least you take the guess work out of trying to put two rings down.
