Rusted Through Cast Iron Vent Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2012, 04:08 PM   #1
Rusted through Cast Iron Vent stack
My home is a 1955, Single Floor house on Pillar and Beam. When we were running our Dish washer, I noticed the Water running on the outside of the House from behind the external wall. After getting under the sink, I could tell the problem was behind the drywall. I removed the drywall and found my Cast vent stack has rusted through at the joint and it extends up the stack, at least, a foot or so. To access this Vent stack, should I access the area from the Outside or Do I have to remove my cupboards, counters, etc to repair or replace???
edros is offline   Reply With Quote
Old 09-23-2012, 04:16 PM   #2
Rewards Points: 13,694
What's on the outside for siding?
edros (09-23-2012)
Old 09-23-2012, 04:26 PM   #3
The outside has Vinal Siding over the Original Wood.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Main vent stack moving / resizing / removing (///AG) SFX Group Plumbing 11 11-16-2010 06:47 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
