Rusted At Thread Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 11:04 PM   #1
Unhappy
Rusted at thread cast iron pipe
My house was build back in 1950. The water stop valve for toilet was licked at joints. After I took out the old valve, I saw the thread of the cast iron pipe was rusted and damaged to the end of the thread. I used Teflon tape to tape 2 times by counter clock wise and put on the new valve Brass Craft 1/2 OD.
The leaking is still happen. What should I do to stop the leak?
Home depot carries push in valves like Shark bite brand. can I use those for my cast iron pipe? Please help me. Thanks.
handyman99 is offline   Reply With Quote
Old 01-19-2012, 11:16 PM   #2
Rewards Points: 14,278
It's a steel pipe not cast iron. Try and remove the whole nipple and replace it with a new chrome plated brass one. Your going to need a pipe wrench.
Make plans to replace all of that old plumbing if it's not leaking now it will and it rust from the inside out. It will close up to nothing over time, and rust will continue to flake off plugging your faucets and toilet flush valve.
handyman99 (01-19-2012)
Old 01-19-2012, 11:21 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If you have access to the fitting the pipe nipple screws into life will be much easier for you.
Try heating the fitting where nipple screws into it a little then get pipe wrench as close to the fitting as possible before turning it.
Install teflon tape in clockwise direction,same as you install valve to tighten it
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 01-19-2012, 11:35 PM   #4
There is no slide on or compression fittings for steel pipe.
Old 01-20-2012, 07:58 AM   #5
Rewards Points: 152
If you can't replace the nipple...
- remove valve
- 3-4 wraps of teflon tape in a clockwise direction
- spread pipe dope over the tape
- thread back together
Should be good to go!
burnt03 is offline   Reply With Quote
The Following User Says Thank You to burnt03 For This Useful Post:
handyman99 (01-20-2012)
Old 01-24-2012, 11:13 PM   #6
- remove valve
I followed your tips and problem was solved. No more leaking.
I almost to replace the new nipple and I do not want to cut big hole around a pipe to access to the fit and nipple.
Again, thank you.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
cast iron pipe tnhldtch Plumbing 2 11-13-2011 09:19 AM
how do I bond pvc pipe to cast iron 1badmf Plumbing 10 08-15-2011 09:57 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Old Toilet Flange on cast iron pipe ahuberpsu Plumbing 4 05-17-2010 07:04 AM
