Rusted On Faucet Brass Hex Nut - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2010, 07:03 PM   #1
Rusted on faucet brass hex nut
I'm trying to replace a 17 year old faucet that's in our bathroom and unfortunately I'm encountering some rust issues. The bolts holding down the faucet and the hold/cold handles is a slim brass hex nut, as opposed to a regular plastic or wingnut based one. The cold water hex nut came off relatively easy with no corrosion, but the hot water one is stuck on with rust and limescale and I can't get it off. I tried WD40 and PB Blaster, tried turning it as best as I could with flat pliers (basin wrench won't latch onto it because it's so thin width wise) with no avail. I even went as far as hammering the hot valve in both directions to try to break the nut loose, which worked with the faucet portion, but with no avail. Is there any way that I break this thing without breaking the sink? I'm trying to avoid having to call a plumber because it's such a simple thing. Is there a hacksaw small enough to fit in there so that I can cut it off?
wysiwyg6000 is offline   Reply With Quote
Old 02-21-2010, 07:14 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
find a long straight bladed screwdriver and split the nut off there with a hammer.maybe throw some anti seize on the threads of new faucet if theyre metal to make it easier to remove in future
plummen is offline   Reply With Quote
Old 02-21-2010, 07:33 PM   #3
Thanks for the reply. I actually was starting to hit the nut with a straight screwdriver and hammer, but didn't hit it too hard or for too long because I was concerned that I might crack the porcelain sink. Is there an alternative to this? I've heard that some plumbers might take a torch to it and try to heat it in order to break the seal...not sure if that's a good idea though with the WD40 and PB Plumber residue on it.
Old 02-21-2010, 07:47 PM   #4
plummen's Avatar
its pretty hard to break a sink,just be carefull.your more likele to damage the sink with a torch than splitting that nut
Old 02-21-2010, 08:09 PM   #5
Rewards Points: 352
dremel
plumberinlaw is offline   Reply With Quote
Old 02-21-2010, 10:36 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by plumberinlaw View Post
dremel
You're right in front of me 2 times with the correct answer.
Journeyman Plumber
Old 02-22-2010, 02:18 AM   #7
or go to sears and buy a nut splitter. you tighten it over the nut and it will split. nice handy tool.
plumber Jim is offline   Reply With Quote
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 04:32 PM
Another "Kitchen faucet replacement" thread! :) emperor_black Plumbing 3 07-27-2009 11:44 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Faucet Repair Questions? mfleming Plumbing 3 05-07-2008 10:44 AM
