Rusted, Broken Bathtub Diverter Screws - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2011, 02:23 PM   #1
Rusted, broken bathtub diverter screws
just tried to replace the bathtub diverter and both screws holding the level plate broke off. There is just a little stub of a rusted screw left. Any idea how to extract the screws or is there someother idea?
Steve Burke is offline   Reply With Quote
Old 02-13-2011, 03:03 PM   #2
picture = 1000 words
your post = 39 words
therefore
your post = .039 pictures
if you can, post a pic so we have an idea of what you're talking about and give the best advice possible
the_man is offline   Reply With Quote
Old 02-13-2011, 07:06 PM   #3
Rewards Points: 1,418
You could try using some Liquid Wrench, waiting a day, and twisting the remains of the screw out with pliers. More likely you would have to drill the screws out and retap the holes in the flanges.
Old 02-14-2011, 01:58 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I have a little kit with two sets of different size screw extractors in it. Costs about $19.95 off the TV, but I bet you could get them at any big box.
The kit has the two sizes with two screw extractor pieces each. One drills a concave hole in the broken off end of the screw, and the other bites into it with the drill in reverse and backs it out neat as a pin. Works sort of like a pipe Easy-Out, but way smaller.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-14-2011, 02:08 PM   #5
Steeler99's Avatar
therefore
Um, for the record, that is awesome....hahaha, very well put..I can't believe ya counted the words!!
Steeler99 is offline   Reply With Quote
Old 02-14-2011, 03:30 PM   #6
Rewards Points: 338
Good luck!
Mike
you mean like this? i have a set too and they are cheap and can certainly come in handy.
NitroNate is offline   Reply With Quote
Old 02-15-2011, 11:00 AM   #7
Thanks to you all! Tried the extractor but it broke in the hole. Ended up using a Dremel with an abrassive disk to flatten the screws, and extractor against the brass overflow flange. Then drilled and retapped 1/4-20. Works well now.
bathtub diverter spout LCarlisle Plumbing 5 05-21-2009 09:18 AM
Broken spout on bathtub jmilesrcr Plumbing 5 04-18-2009 11:18 AM
Broken Diverter? Need HELP! URGENT!!! esadiek Plumbing 2 09-07-2008 09:31 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 07:44 PM
