Rust In Well Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2014, 09:41 PM   #1
rust in well water
hey folks. i have just recently purchased a home in the country. I have a fairly new water heater and softener. my water coming out of the faucets is rather rusty. any suggestions?
adampeach is offline   Reply With Quote
Old 02-02-2014, 09:47 PM   #2
Rewards Points: 13,450
Old steel plumbing? If so it always will be rusty water unless you replace it with something like Pex.
Old steel pipes rust out from the inside out. At some point it's going to leak and close up on the inside reducing the flow.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
adampeach (02-02-2014), jmon (02-02-2014)
Old 02-02-2014, 09:58 PM   #3
ok. im in southern ohio. house built in 79. are you saying pipes from well pump to softener or pipes inside home?
Old 02-02-2014, 10:01 PM   #4
All of it, any steel pipes or fittings need to go.
Old 02-02-2014, 10:14 PM   #5
ill look into that. should i be checking softener or water heater also
Old 02-02-2014, 10:36 PM   #6
Agree with Joe, would check and see what kind of plumbing you have first. Some pictures would help.
How old are the hwh and softener? You stated they're fairly new.
jmon is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
