Rural Water Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2012, 08:13 PM   #16
Homerepairguy's Avatar
Rewards Points: 990
Originally Posted by socdog View Post
Have you all heard of any problems with PEX? It sure seems easier to work with. I may be dancing around some big stumps.
Do you have underground rodents in your area? If so, they might chew through the PEX to get at the water. No personal experience but that's what I read when researching PEX for our home.
HRG
Homerepairguy is offline   Reply With Quote
Old 04-15-2012, 10:42 PM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
HRG
I've read that too, but i'm not sure what the difference between that and schedule 40 PVC or, HDPE piping would be.
I've never seen that happen in either case, around here, and we do have lots of gophers.
Journeyman Plumber
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 08:39 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
