Rural Northwest Florida Water - Need A Softener? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2014, 07:28 PM   #1
Rural northwest Florida water - need a softener?
We live in northwest Florida (not the panhandle) - our water compared to most Florida is actually very good - no sulfur smell etc - taste is best 'straight from the ground' water I've ever had in Florida but we have one issue - rust - we don't really have any filtration systems or anything like that coming from the well into the house (that I'm aware of) so periodically I have to clean out the washing machine as it gets clogged with these little rust 'flakes' - we're somewhat new to this home and so far as I know there is only one line leading in having said that I have not noticed any of these flakes in the drinking water (now that I say that they're probably being captured by the faucet).... is there some way I can filter this water WITHOUT sacrificing the water quality - I hate to run it through a softener or something when the water is good - however I'm very concerned about what is happening to the pipes and what preventative I should do to prevent potential damage to appliances etc.
migofast is offline   Reply With Quote
Old 03-26-2014, 07:48 PM   #2
Rewards Points: 1,666
Time is drawing near when you'll need to replace the rusted pipe(s). In the meantime you can install a filter but the location will be critical in order to contain the rust particles. If the rusty pipe is between the well and house the filter will need to be at or near the house.
If the rusty pipe is within the house you have a bigger problem. As for your laundry unit keep the finest screen in the inlet hoses you can find. The hot water may not be a problem being the rust will probably be in the bottom of the water heater if the rusted pipe is before the heater.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Javiles (03-26-2014), migofast (03-26-2014)
Old 03-26-2014, 07:52 PM   #3
Rewards Points: 582
install a sediment and rust filter before holding tank..and install taste and odor filter after holding tank....use valves on both sides of filters for srevice..
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 03-27-2014, 07:14 AM   #4
Rewards Points: 13,960
Just a guess, old steel pipes in the slab?
At some point all steel pipes will close up on the inside and start leaking because they rust out and need to be replaced.
Most people replace it with Pex tubing running through the walls.
In your area you may get away with running it through the attic.
Old 11-29-2014, 01:15 AM   #5
hdonly0's Avatar
Rewards Points: 14
For a quick temporary help, you can try going to the farthest faucet outside from the water entrance to the house and open it up and let it flush for a while. You may have to do this on a repeating schedule as needed. It won't cure the problem, but it may help get rid of particles that are laying loose in the old galvanized pipes.
hdonly0 is offline   Reply With Quote
Tags
florida , rust , softener , water
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Well water + water softener led to low water flow AmandaJayne Plumbing 2 02-19-2013 11:00 AM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
