Running Waterline To Pasture - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2010, 01:30 PM   #1
Running waterline to pasture
Hello.
I am considering a job as a barn manager in NC. One of my first "major" projects will be to run water to a pasture. I am not sure how far it is from the water source to the pasture, so I was wondering if there is a formula for figuring pipe size to reduce the effects of distance on the water pressure. For example, if the run is 150 ft, use x size pipe, where if the run is 1500 ft, use y size pipe?
McGinnis is offline   Reply With Quote
Old 09-25-2010, 01:52 PM   #2
Not sure if this will help you, but it gives a formula for pressure and volume loss.
http://www.newton.dep.anl.gov/askasc...9/eng99404.htm
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 05:00 AM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 01:45 PM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
