Old 09-12-2008, 02:17 PM   #1
Running water to my barn
Hello all,
I'm planning on tapping into my home water line that is supplied by a drilled well so I can run water to my barn. The barn is 350' from the house. I live in the North East so I'm digging at trench at least 4' down to bury the line. I've got a backhoe so that part of the job is pretty straightforward. I'll be installing a frost free hydrant at the barn and putting in a gravel dry well for that to drain into.
My question has to do with punching through my fieldstone foundation to get the line into my basement. I'll rent a power tool to make the hole. It will probably be a rotary drill of some sort. But once I've got the hole and put the line through it, what do I do to seal the pipe? Does it need to be sleeved? Insulated? Protected? The line is 1 1/4" ABS. Can I simply use hydrolic cement?
oldspice is offline   Reply With Quote
Old 09-13-2008, 01:03 PM   #2
I would sleeve it. A piece of 1-1/2" or 2" should slide over it .Use the hydraulic cement around the sleeve. You want something with some flex between the pipe and the sleeve. Your foundation does move a bit with temperature changes and if you had cement against the plastic pipe, it could cause a leak.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-15-2008, 08:18 PM   #3
Over the weekend I was able to start the trenching and excavated the foundation. I used a rotary hammer type drill that had both a feature that allowed either both hammer and drill or just hammer. I used the hammer more than the drill part and made a 2" hole. The foundation was about 16" wide at the point I started drilling which was about 5' down from ground level on the outside.
I took majakdragon's recommendation and put a 1.5" pvc pipe and cemented that into the hole with the cement. I'll then slide the water line through that. I suppose I should caulk that with some silicone or something to seal that but allow it to move like you say it should.
Thanks!
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Water well running dry? Proulx06 Plumbing 4 02-28-2008 10:17 PM
Running hot water causes pipe rumbling mpinchinat Plumbing 13 12-25-2007 12:13 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
Running Water makes pipes moan MikeRatliff Plumbing 2 01-25-2007 07:47 PM
