Running Water Makes Pipes Moan - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2007, 03:07 PM   #1
Question
Running Water makes pipes moan
Earlier this year a horrible noise started in our house whenever water is run from any bathroom outlet. It does not seem to do this when the dishwasher, kitchen sink or refrigerator water is run. It is only in our two bathrooms on the ground floor and the bathroom on the second floor. It seemed to coincide with our half-bath toilet starting to "run" a lot. The fill valve had a label on it that said it was a special water pressure valve. The squealing, moaning sound was really getting obnoxious whenever water was run. I replaced the fill valve and that fixed the "running" problem, but the moaning/squealing noise is as loud as ever. Any ideas?
MikeRatliff is offline   Reply With Quote
Old 01-25-2007, 04:24 PM   #2
Welcome to the Chatroom. I am guessing that the problem is a washer or "O" ring on one of the bathroom faucets. Try turning off the water supply lines (one at a time) under the sinks. Then turn on water at a place that would usually make the pipes squeal. When one of the supplies is off and the noise doesn't appear, thats the faucet you need to repair. See if the test works and if so, let us know if you need help with the repair. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-25-2007, 06:47 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Check the water pressure on the house, test with a pressure gage that connects to an outside hose bibb, there is a possibility your house pressure is too high.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
Water sound in Pipes Robb Plumbing 14 12-26-2006 10:48 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
