Running Water Line For Refridgerator.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2009, 09:24 AM   #1
Running water line for Refridgerator..
Hi... I have a quick question..
We are moving our refrigerator to an opposite wall during a kitchen remodel. I need to re-run the water line, and I have about 25 feet of 1/2 Pex left from a prior project... If I "T" off a 1/2 supply line and run the PEX up through the attic and down out behind the fridge, what is the easiest way to connect the 1/2" line to the 1/4" copper line required for the fridge?
Should I use a stop valve? And if so, what kind of connector can be used between the stop valve to get it down to the 1/4"?
dirtmcgirt79 is offline   Reply With Quote
Old 06-18-2009, 10:27 AM   #2
HVAC / Plumbing
yes you should install a shut off valve... You should be able to find all the fittings you'll need at local lowe's , hd, plumbing supply
kenmac is offline   Reply With Quote
Hot water keeps running Ed36 Plumbing 4 05-14-2009 12:39 PM
Need Advice - How to run Fridge Water Line Joshcube Plumbing 3 03-20-2009 04:56 PM
Water softener off the main line? scottyja Plumbing 1 02-03-2009 07:16 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
