Running Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 01:33 PM   #1
Does everything himself.
Exclamation
Running Tub Faucet
So we have a running bathtub faucet with a single-handle control. After doing some research online I determined that the source of the leak must be the valve in the single-handle control. I removed the handle and this is what I saw:
Do I need to replace that whole thing? Or is there a way to open it up and replace some washers or o-rings or something?
Any information would be greatly appreciated.
Thanks.
w1nk5 is offline   Reply With Quote
Old 01-08-2010, 07:58 PM   #2
has no one ever seen one of these before?
Old 01-10-2010, 06:12 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
moen single handle non posi-temp faucet,ive installed hundreds of them.best faucet ever made in my book.anyway any decent hardware store should stock that cartridge for $15-20.turn water off to house and let it drain down,then pull that little horseshoe clip out from top .sometimes you can just grab the end of stem with channel locks and pull it out,other times you need a puller.make sure to put vaseline or plumbers grease around new one when installing.if the hot/cold are reversed when you turn water back on just turn off the water to house,pull the clip and spin cartridge 180 degrees and turn water back on.
plummen is offline   Reply With Quote
Old 01-12-2010, 09:03 AM   #4
Thanks a lot, I really appreciate it.
Old 01-12-2010, 12:22 PM   #5
plummen's Avatar
no problem!
Another "Kitchen faucet replacement" thread! :) emperor_black Plumbing 3 07-27-2009 11:44 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Running Faucet qupert Plumbing 6 02-25-2008 12:45 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
