| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Remove a Toilet Wax Seal
by Expert Village
Today we’re replacing the toilet. We’re just about to install the new toilet. It’s been pre-assembled a while ago. What you want to do in here is get all this old caulking off the floor because you’re going to have to re-caulk it... Read More »
Water Tube for a Colon Cleanse
by Expert Village
Okay some things you want to look for when you get an colonic is obviously that your therapist wears gloves and that you ask that there is disposable tubing and disposable speculum. Back in the day they used to use metal speculums which you would have to... Read More »
How to Inspect a Motor Oil Drain Plug
by Expert Village
Hi! My name is Dean and on behalf of expertvillage.com, in this clip we are going to talk about inspection of the drain plug. It is very critical that when you get the drain plug out that you look at the threads and make sure they feel nice and they look... Read More »
How to Install Transmission Gasket
by Expert Village
In this clip we're going to talk about the proper way to install the gasket onto your transmission pan. Performing this step will save you a little heartache, trying to line the pan up with the gasket to the transmission case. What I'm going to do now... Read More »
How to Maintain a Car Cooling System
by eHow.com
From the water pump to the head gasket and radiator, the cooling system of the car is the heart of the engine. It should be inspected and maintained on a regular basis. By keeping all components of the cooling system running optimally, you can extend the... Read More »
