My sump pump in my crawl space runs out of the house and then 50 feet slightly down hill through PVC Pipe to the back of my yard. The pipe runs under concrete decking. The pipe is broken and when the sump pump fires up I can see water comming from under the concrete.
I want to T my sump pump line into my washing machine discharge line that draines into the sewage system. I am on city sewage.
Is this ok?
Why didn't the home builder do this in the first place?
If everyone had their basement pumping into the sewer then when there was a heavy rainfall it would put a high demand on the sewage treatment plant. And their may be oil or other chemicals that may get into the water system.
In the past, it was legal and common to mix sanitary and storm sewage. The sewers were called common sewers an comtained normal sewage that took treatement and storm water that usually didn't require treatment.
Then they found out it was costing a fortune to treat all the storom water AND the sewage since it could not be separated once it was in the pipe. On top of the treatment cost, there was the cost of building and maintaining twice the treatment capacity.
Now, it is illegal to make new hook-ups in most areas. Most older cities are separating the street drains from the sewer drains where possible rather than building additional treatment capacity because it is cheaper to be split in the end.
Unfortunately, there are still many roof drains going into the sewer lines at the house.
Where I lived at one time years ago, when there was a big storm, the excess sewer flow was just dumped in the river and not treated. Everyone downstream did not take kindly to it, so the systems were separated.
It does not look like much, but it certainlt counts up at the wrong time.
Reasons have been stated, oils and contaminates going into the sewer system is bad, reclaimed water get returned back to the rivers and streams, it's all about the enviroment.
Plan B - direct water to neighbors yard and let them get rid of it.:jester:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
