Running PVC Pipe Through Joists - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2012, 11:46 AM   #1
running PVC pipe through joists
Is it ok to heat pvc to make it more flexible so I can feed it through the floor joist holes. Otherwise I need to put a coupling between each joist.
Doug60m is offline   Reply With Quote
Old 04-02-2012, 01:06 PM   #2
Rewards Points: 1,578
Not sure about heating it (people do it; how I'm not sure) but be sure you are not drilling too large a hole or too close to the edges of your floor joists (you'll weaken them and have a bigger problem).
Search this site or google for hole size and placement in a joist; this has been covered a bunch of times.
What size pipe and what size joists?
bob22 is offline   Reply With Quote
Old 04-02-2012, 01:29 PM   #3
MarginallyQualified
Rewards Points: 2,464
Er... that's a BIG fat NO.
Otherwise I need to...
Otherwise... you you need to install the pipe BELOW the joist.
Something like this:
Old 04-02-2012, 02:34 PM   #4
Rewards Points: 338
the ONLY time i see where it is legit to bend PVC is for pool installs where the PVC has to curve to the shape of the pool. but they use special torches and it takes a lot of expertise and practice to do it successfully without weakening the PVC.
NitroNate is offline   Reply With Quote
Old 04-02-2012, 05:33 PM   #5
Thread killer
Rewards Points: 272
How thick is the pipe? I put 9 ft of 2 inch ABS through a 2x6, 16 inch centre wall without needing any heat. Granted, you need room behind it to start and a big hammer. Got easier once i was through the second stud.
Canucker is offline   Reply With Quote
Old 04-02-2012, 05:47 PM   #6
MarginallyQualified
Originally Posted by Canucker View Post
...Granted, you need room behind it to start and a big hammer.
I once removed some siding and sheathing on a building in order to get pipe (over 600LF of 3" PVC) into the joists between floors. That was a fun day.
Old 04-02-2012, 05:51 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
How about some Vaseline or other lubricate to help get it through?
sublime2 is offline   Reply With Quote
Old 04-02-2012, 07:05 PM   #8
Homerepairguy's Avatar
Rewards Points: 998
Have you considered using PEX tubing instead?
HRG
Homerepairguy is offline   Reply With Quote
Old 04-02-2012, 09:52 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Here's a thought :
What are you using the pvc for?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Homerepairguy (04-03-2012)
Old 04-02-2012, 09:58 PM   #10
Rewards Points: 13,472
Is this a drain or supply line?
Suppys should be copper, Pex or CPVC not PVC.
No way do you want to have couplings every few ft.
Old 04-03-2012, 06:03 AM   #11
More answers than questions. Where did the OP go?
Old 04-03-2012, 09:13 AM   #12
Doing it myself
Alan's Avatar
To go buy a blowtorch.
Journeyman Plumber
Old 04-03-2012, 09:48 AM   #13
and some astroglide
The Following User Says Thank You to bob22 For This Useful Post:
Ravenworks (04-03-2012)
Old 04-03-2012, 04:05 PM   #14
Task done, 1 1/2 inch pvc. My weight was enough to bend it and then banged on the end to move it along. Thanks for all the thoughts.
Old 04-03-2012, 08:46 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 568
I can't count how many greenhorn apprentices I've watched struggle with this. I finally have pity on them and show them another "trick of the trade"
Running Copper Pipe Through Bottom Plate? ddawg16 Plumbing 4 08-15-2011 11:16 PM
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 12:42 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Question about running NM and BX in joists stock2mal Electrical 1 06-14-2010 02:45 PM
running black gas pipe lukeg Plumbing 6 10-24-2009 11:16 PM
