Running Plumbing For Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2012, 09:23 AM   #16
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I have to keep the numbers for all the electrical/hvac/plumbing inspectors for 3 differant towns on my phone,its around 13 of them in each town i deal with!
plummen is offline   Reply With Quote
Old 01-10-2012, 10:05 AM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Why didn't you just thread a male adapter in where that cleanout is and use that for your utility sink drain?
Journeyman Plumber
Old 01-10-2012, 10:09 AM   #18
plummen's Avatar
It would still have same issues with soap
Old 01-10-2012, 10:57 AM   #19
I assumed that the cleanout access shouldn't be taken away. But I suppose it would be easy to simply unthread the connection to access the cleanout. Oh well.
So it sounds like the only issue here is that suds from the washer could creep up into the utility sink. I should run a load and see what happens.
If it turns out this is a code violation, I can cap the tee that I cut and try running it to the main drain pipe, but it is on the other side of the basement and not in a good area for a sink.
BobUrban is offline   Reply With Quote
Old 01-10-2012, 10:36 PM   #20
Doing it myself
Alan's Avatar
Yeah I was thinking more in terms of elevation problems since people were talking about putting 2x4's under the legs.
There's no reason you can't put the cleanout in the wall above the sink. Probably be easier to access that way anyhow. Minimum cleanout size for a 2" drain is 1-1/2"
Of course I had a situation once where I had to put a 1/2" cable down a 2" drain and I was glad that the 2" cleanout was there.
Journeyman Plumber
Plumbing pedestal sink G Archer Plumbing 1 01-30-2011 04:34 PM
Washer and Utility sink in a room that has never had plumbing mattreyno Plumbing 1 12-28-2009 10:22 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
PLEASE HELP..Kitchen Sink Plumbing!! davo420 Plumbing 6 02-28-2006 07:37 AM
