Running Plumbing Through Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2009, 07:15 PM   #1
running plumbing through slab
a little nervous to try this, the slap is suspended, a foot thick in most areas can i run a tub and shower drain through a maybe 4x4 inch deep trench then fill in, or will the slab crack or buckle, the run is about 9 feet, no crawl underneath only a few inches, any advise would be appreciated before i try this, thanks jd
jod11 is offline   Reply With Quote
Old 09-29-2009, 07:48 AM   #2
Rewards Points: 1,500
I would not want to jackhammer or diamondsaw out a groove or channel or trench that size within the concrete slab.
It would require some engineering to figure out whether the slab could still withstand the stresses and loads it is expected to should such a trench be carved out.
OT: My uncle had a hole (about 18 inches square) cut through a floor slab to get at a pipe leaking down below but, heck, the house was over 50 years old. (Ultimately a new pipe was strung overhead rather than fix the existing broken pipe.)
Old 09-29-2009, 09:43 AM   #3
Civil Engineer
Rewards Points: 4,700
What is a suspended slab? Do you possibly mean a floating slab?
Old 09-29-2009, 03:58 PM   #4
i think it is possibly a floating slab, will try cutting then chiseling not to crack the slab
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 03:48 PM
