Running Pitched Drain Through Joists - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2010, 11:14 AM   #1
Knows everything but that
Rewards Points: 150
Running pitched drain through joists
So what is the best way to drill and run 1 1/2 in pvc piping through joists? Ive learned that I need 1/4" per foot pitch. Since Im unable to run the entire length with one solid pipe, I assume Ill just run one pipe with a junction between each joist. Will this give me enough flexibility to get this pitch? Also, from others expiriences, is it better to measure and drill the holes in advance to running the piping or to do each joist one at a time as I run the piping. Im running the pipe about 6 feet. I believe its through 4-5 joists as theyre on 16 on center. Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 04-30-2010, 11:37 AM   #2
Rewards Points: 150
Originally Posted by DOC'S HANDYMAN View Post
Not good to run pipe through joist weaken structure
Ive been told otherwise, assuming its done properly. Can someone back me up on this?
Shane
Old 04-30-2010, 12:01 PM   #3
how low on your first joist and what size joist
The older I get the better I was
Old 04-30-2010, 12:19 PM   #4
Rewards Points: 150
They are 6 inch joists and I can start it at any depth.
Shane
Old 04-30-2010, 12:24 PM   #5
Rewards Points: 1,514
The problem is that the hole may not be too close to either the top edge or the bottom edge. This severely restricts the manner in which you can slope the drain pipe.
I am not sure what the limits are but I thought it was no closer than 2 inches to the edge.
Old 04-30-2010, 12:29 PM   #6
2x6 i would say no, not enough wood
Old 04-30-2010, 12:48 PM   #7
Rewards Points: 150
Thats what she said...
Anyway, I was calculating wrong. I was measureing from the top at both places not thinking about the bottom of the pipe being too close at the end. Shoot, I guess Ill have to find another way. Thanks!
Shane
Old 04-30-2010, 01:50 PM   #8
Military Mom of 4
Snav's Avatar
Why are you having to consider going through the joists? Are these pipes being installed in a ceiling/floor?
what are your other options? Through a wall, instead of across the joists - maybe you can send the drain line down between them longways and relocate your connections?
Describe your plumbing situation - everything has more than one solution.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-30-2010, 02:00 PM   #9
Rewards Points: 150
Well, Im now thinking that I may be able to go along the joists, out into the knee wall area and then over the the joist run where the drain is located. Im just hoping that I can get enough pitch in the pipes this route. Otherwise, I think Im in real trouble.
The setup is really hard to describe and I cant figure out how to post a paint document as it keeps telling me the size isnt correct no matter how small I make it.
Shane
Old 04-30-2010, 02:35 PM   #10
there a reason you see boxed in areas in some rooms just for this reason
kennzz05 is offline   Reply With Quote
Old 04-30-2010, 02:38 PM   #11
Rewards Points: 150
I dont understand what you mean.
Shane
Old 04-30-2010, 03:04 PM   #12
ever see a room with a portion of the ceiling that has a boxed in area,located in one corner of the room? picture a duct running thru the room to another location you make a covering to hide the duct with 2x4s and drywall. you could do the same thing for your drain. sorry i dont know how to describe it better or do those things where you can draw a picture and than post it on here.
Old 04-30-2010, 03:16 PM   #13
Rewards Points: 150
Gotcha. I think, if it is allowed, that running it through the knee wall is feasible. Ill just have to measure to be sure when I get home.
Just a quick note then. With the drain for the tub coming right off the bottom of the tub, since a 45 degree elbow would put too much pitch on the drain pipe, how do you get the proper drop per foot? Does the PVC have enough flex to do this without stressing the glued joints too much?
Shane
Old 04-30-2010, 03:25 PM   #14
Military Mom of 4
Snav's Avatar
You mean - instead of a 45 you'd use a 90?
This doesn't matter, actually - because your S or P trap will be near the tub - this actually gives a bit of play room and allows for the remainder of the pipe to slope properly.
If you have a long run of PVC, though, it will be able to flex a bit - but it's never ideal to force it to flex too much - that puts undo stress and might lead to fractures and collapse.
there are several sizes of joints sold: 90, 60, 45 and 22 - by combining a few of these with your needed length of pipe you can get whatever shape or slope you need.
so - if I had to do your work - and I was limited by space to using a 90 I would quickly follow behind that with a 22 to get the pipe to begin to slope downward. If that slopes too much - then I'd install another 22 along the pipe to keep it from being too steep.
Old 04-30-2010, 03:26 PM   #15
if i remember you said youre going 6 feet thats only an 1" 1/2 of drop shouldnt be much problem to get that using pvc, just glue it with the slope in it already. dont forget to use primer before you glue it
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 09:46 AM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
running washer drain sedwick Plumbing 8 02-12-2007 05:10 PM
