Running Pipes In Outside Wall (Basement) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2010, 10:45 AM   #1
Rewards Points: 640
running pipes in outside wall (Basement)
I am in the process of refinishing our basement, we already have a bathroom where the sink and toilet are on the outside wall of the house. The pipes right now come in from left and right of the room from other finished spaces but are exposed inside the room and look horrible... now I know why they did that, they only built the all with furring strips then drywall on the outside walls... I am about the demo this room and redo it as a 2x4 back wall with XPS foam behind it then R-13 insulation in the wall... my question is, can I run copper pipes in that new 2x4 wall? Will it be a freeze risk since its between XPS foam and wrapped in fiberglass insulation before the drywall?
This wall is below grade and where the pipes would run is 7 feet below grade, well below the frost line.
BlueBSH is offline   Reply With Quote
Old 10-18-2010, 11:30 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
You'll be fine.
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 10:57 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 10:54 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
