Running Pipe Up Through Floor...Yes/No? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2012, 11:01 AM   #1
Topic Hunter
Focker's Avatar
Rewards Points: 79
My Mother in-law wants me to install a pot filler above her range. Currently the studs above the counter are exposed therefore we thought why not...Should be easy right. I pulled out the range and noticed a gas line coming up through the floor and not in the wall...Hmm? I drilled a small pilot hole behind the range to assist me in located the stud plate once I went into the crawl space. Once under the house I found the pilot hole and went to measure over to where the wall would be and discovered a support beam running parallel with the wall. Now I see why the gas line went up through the floor (or maybe that's common).
I explained to my In-laws my findings and suggested we don't drill through the 4"x8" load beam. Now they want me to bring the supply up through the floor like the gas line, elbow into the wall at its base and then proceed up through the wall as intended. I'm using 1/2" CPVC, GatorBite fittings and should be able to connect everything without too much effort. I will be installing a shut off valve in the crawl space that supplies the new pot filler.
Up top...The supply will be protected by the range and never seen. They are retired, the home was built in '94 and it's paid off. I don't see them moving until they are forced, due to health etc.
Thoughts?
Focker is offline   Reply With Quote
Old 06-19-2012, 12:19 PM   #2
Rewards Points: 2,516
Damn the torpedoes and do it.
But drilling a 5/8" hole near the center of a 4x8 beam should not compromise it.
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
ben's plumbing (06-22-2012), oh'mike (06-19-2012)
Old 06-19-2012, 12:29 PM   #3
DIY staff
Rewards Points: 7,174
The pipe will be protected by the stove--so why not? Get it done---Mike---
Old 06-22-2012, 10:50 AM   #4
Topic Hunter
Focker's Avatar
Rewards Points: 79
Knocked it out yesterday!
Went up through the floor and it turned out great. The GatorBite fittings are awesome to work with.
Sent from my mobile using DIY chat room app.
The Following User Says Thank You to Focker For This Useful Post:
Old 06-23-2012, 01:36 PM   #5
What I do in that instance, is drill a hole through that bottom plate on an angle to keep you in the wall but it comes out in front of your beam once you get past the floor level.
Pmmcgillis is offline   Reply With Quote
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
running black gas pipe lukeg Plumbing 6 10-24-2009 11:16 PM
Running Pex Pipe? sandyman720 Plumbing 2 09-05-2007 01:03 PM
