Running Pipe Through Joists - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2010, 11:54 AM   #1
Just call me Andrew
Rewards Points: 1,020
Running pipe through joists
I need to run 1" copper pipe in my basement that will cross 2 joists.. Is a 1.25" hole too big to put in a joist? I think (have to verify) the basement has 2x6 joists - possibly 2x8, I can verify when I get home.
Running under the joists isn't really an option due to the low ceiling. There's a dropped ceiling, but there isn't roomfor a pipe that big between the dropped ceiling and the joists.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 07-08-2010, 11:58 AM   #2
Knows everything but that
Rewards Points: 150
That hole should be fine. From what I understand, the pipe can be no closer to the edge of the joist than 2" and no larger than 1/3 the actual size of the joist. Seems to me a 1.25 inch hole is well within those limits.
JakAHearts is offline   Reply With Quote
Old 07-08-2010, 12:02 PM   #3
Just call me Andrew
Thanks. I actually just found this in the NY Building Code:
Originally Posted by NY State Building Code
Holes bored in joists shall not be within 2 inches (51 mm) of the top or bottom of the joist, and the diameter of any such hole shall not exceed one-third the depth of the joist. Notches in the top or bottom of joists shall not exceed one-sixth the depth and shall not be located in the middle third of the span.
Andrew
Old 07-08-2010, 01:09 PM   #4
Rewards Points: 150
Hey, I was right!
Shane
Gas Pipe General Questions jamiedolan Plumbing 10 12-06-2012 10:46 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Question about running NM and BX in joists stock2mal Electrical 1 06-14-2010 02:45 PM
running black gas pipe lukeg Plumbing 6 10-24-2009 11:16 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 11:15 AM
