#1 |
Running Pex Pipe?
What is the best way to run pex pipe through corner wall studs?
#2 |
Running Pex Pipe?
I don't think you will without crimping it closed. If you have to run it that route, carve out a groove in the framing, install the metal corner bend and cover with those metal plates so you don't put a drywall screw through it.
Ron |
#3 |
Running Pex Pipe?
As Ron6519 implied...is there another way to run the PEX so that it doesn't need to run through a corner? What are you feeding that requires it to go through a corner? If you have access, it would be better to run from below the floor ( i.e. basement) so that you can just stub up from underneath to feed the fixture above. This will allow nice soft bends in the PEX to eliminate any worries of "pinching" it.
| Display Modes | |
| Use of coupling fitting on gas pipe | Fred | Plumbing | 3 | 01-28-2007 07:13 AM |
| Replacement pipe for hot water heat? | Tmb9862 | HVAC | 18 | 01-12-2007 04:31 PM |
| Need to support 15th of ABS pipe | irishtimes101 | Plumbing | 3 | 09-01-2006 12:09 PM |
| Gas dryer pipe | jscholl411 | Plumbing | 1 | 06-07-2006 09:21 AM |
| Vent Pipe Leak | romeguy1 | Plumbing | 9 | 12-11-2005 01:08 AM |
