Running PEX In Mobile Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2013, 10:41 PM   #16
Rewards Points: 2,040
Your heater should have come with 2 stainless steel dialectic nipples. The usually are already mounted in the hot and cold inlets. Since your tank is electric you can run pex all the way to the nipples. Use a FIP adaptor with pipe dope and tape.
Old 07-02-2013, 11:03 PM   #17
Electrical Enthusiast
Rewards Points: 504
I haven't actually bought the heater yet.
When I do I may come back.
Kyle_in_rure is offline   Reply With Quote
Old 07-06-2013, 09:54 PM   #18
Rewards Points: 504
I am all set I think. I do have one more question. The line from the well comes out of the ground as 3/4" PVC sched. 40. How do I transition from PVC to the PEX line?
Old 07-07-2013, 06:55 AM   #19
Rewards Points: 1,702
Originally Posted by Kyle_in_rure View Post
Let me preface this by saying that I have little experience with plumbing.I am in the process of installing a new water heater in a mobile home. (the old one rusted out). All of the plumbing is polybutilene (gray hoses of death). We are on a well so I feel that PEX may be the best choice. I know they make sharkbite connectors that will go from PEX to poly (I am not prepared to replumb the entire trailer right now). Here is what I want to do:
-Install a shutoff where the polybutilene comes out of the ground. (The one at the well won't shut completely off)
-Run PEX from there into the trailer and into the water heater (can you connect PEX directly to the heater? There is some sort of flexible copper fitting there now)
-Run PEX from the water heater to a point where I can transition back to the polybutilene.
Does this make sense/sound reasonable?
Why transition back to PB? Do they make a PB now that is superior in quality to the old Class Action PB?
justplumducky is offline   Reply With Quote
Old 07-07-2013, 07:49 AM   #20
Rewards Points: 504
Nope. Can't afford to do it all right now. This is my question currently. ^^^
Old 07-07-2013, 09:32 AM   #21
Oh ok, sorry - I misunderstood. You meant transition back to the existing PB. I jumped to a conclusion there. I thought you meant transition back and continue on with new PB. My bad.
The Following User Says Thank You to justplumducky For This Useful Post:
Kyle_in_rure (07-07-2013)
Old 07-07-2013, 09:49 AM   #22
Plumber
TheEplumber's Avatar
Rewards Points: 818
glue PVC male adapter on the pipe, then screw a PEX female onto it.
DON'T use pvc female adaapters
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-07-2013, 01:07 PM   #23
Rewards Points: 504
Yeah haha. No way I would try to run "new" polybutylene...... Do they even make it anymore?
Just out of curiosity, Is there a reason you can't use a female PVC fitting?
Old 07-07-2013, 01:15 PM   #24
Plumber
Rewards Points: 818
PVC female adpt. are known to crack. The male fitting can act as a wedge and put stress on the female fitting.
Pipe settlement, lateral movement, expansion/contraction, water hammer effects, etc. all add stress to fittings too.
You can use a pvc female- but I advise against it
Old 07-07-2013, 01:16 PM   #25
Rewards Points: 504
I wasn't planning on it, just curious as to the reason.
Thanks!
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
TheEplumber (07-07-2013)
Old 07-07-2013, 09:38 PM   #26
Rewards Points: 504
Ok, pardon my ignorance.....if I use this to connect to the PEX: (<http://www.pexsupply.com/Wirsbo-Uponor-LF4577575-ProPEX-LF-Brass-Female-Threaded-Adapter-3-4-PEX-x-3-4-NPT>), do I need any sort of crimp ring or clamp?
Old 07-07-2013, 10:15 PM   #27
Plumber
Rewards Points: 818
Yes, you will need to use one of the crimping systems.
I think some of the retail outlets rent the tools
Old 07-07-2013, 10:16 PM   #28
Rewards Points: 504
And that's the only option I assume?
Old 07-07-2013, 10:42 PM   #29
Plumber
Rewards Points: 818
You might check the shark bite line- I assume they would make a threaded adapter. The push fit end works on pex
Old 07-07-2013, 10:49 PM   #30
Plumber
Rewards Points: 818
I vary rarely use sharkbite products- they may fit right on pvc without the glued adapters. I know they fit different kinds of pipe- I'm just not sure which ones
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
mobile home half electric outlets not working...please baby327nd Electrical 11 02-07-2013 10:51 PM
mobile home renovations dbales General DIY Discussions 3 02-05-2013 06:38 PM
Replacing end walls in mobile home. rrolleston Building & Construction 8 02-02-2013 03:19 PM
mobile home deck roof attaching wyomingguy Carpentry 3 08-28-2011 05:07 PM
