Running Out Of Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2013, 02:02 PM   #16
I am on a slab ... only a line to kitchen sink and 1/2 bath run in the slab and its PEX coming out so I assume PEX is in the entire run. Only copper I know of is the main into the house. The home is ~14 years old.
I am going to try a few of the suggestion here in a little bit and let y'all know if I come up with anything
Sean'o ATHS is offline   Reply With Quote
Old 01-03-2013, 02:41 PM   #17
Roofmaster
Rewards Points: 2,172
Check for dirt under the tank and on the intake screen. I bet its shutting itself down for lack of Oxygen. Unplug for a few minutes to reset.
Old 01-03-2013, 05:15 PM   #18
unplug??? unplug what? its not wired to anything just a gas line in...?
Old 01-03-2013, 07:37 PM   #19
Roofmaster
Oh OK its one of the older types with a regular flue.
The Following User Says Thank You to jagans For This Useful Post:
Sean'o ATHS (01-03-2013)
Old 01-03-2013, 07:51 PM   #20
Yes that is correct. I will take some time tomorrow to go through it clean the intake area at the bottom check lines valves etc and drain it ... thank you to all that have tried to help out ...hope to get this squared away and have some info to share for the next time
Help with running new CPVC water lines. Integraoligist Plumbing 0 03-05-2012 02:17 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
