Running New PEX Supply Lines - Which Is Better? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2013, 03:45 PM   #1
Rewards Points: 12
Running New PEX Supply Lines - Which is better?
We will be running new PEX supply lines in our basement as part of a new bathroom.
Just wondering which is the best route to go to maintain the highest level of pressure. This is for the shower that will have two mixing valves - one for a hand shower (2.5 GPM flow rate) and the other for a Delta valve/diverter that will supply a rainhead (2.5 GPM) 2 body sprays (2.0 GPM - total) and a fixed head shower (1.75 GPM). The diverter is a 6 way allowing any 2 of the 3 fixtures to be running at the same time.
1) Run two seperate 1/2" tees off the main line (3/4") to supply the 2 different mixing valves; or
2) Run a 3/4" tee off of the main supply line into the shower area (about 10 feet) and then run a 1/2" tee off of that line to the 2 differnet mixing valves.
Any input/suggestions would be appreciated.
jdm127 is offline   Reply With Quote
Old 05-03-2013, 05:37 PM   #2
Rewards Points: 1,858
Run the 3/4 lines
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
question regarding supply lines psilva8 Plumbing 10 03-06-2012 02:07 PM
Help with running new CPVC water lines. Integraoligist Plumbing 0 03-05-2012 02:17 PM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
Running new Main supply from Meter PEX or PVC? twilightcall Plumbing 7 08-03-2008 07:00 AM
