Running New Main Supply From Meter PEX Or PVC? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2008, 01:49 PM   #1
Rewards Points: 150
Running new Main supply from Meter PEX or PVC?
I am running a new main supply line from the meter to my house. PEX is becoming popular around here for supply lines but most still have PVC. Which would you guys use? I am making a 45 foot run with 1 90 deg. turn. I live in southern TN but it does it get cold in the winter time especially at night. Any info would be appreciated. The rest of the house is plumbed with PEX.
twilightcall is offline   Reply With Quote
Old 08-02-2008, 02:47 PM   #2
Registered User
Termite's Avatar
PVC isn't used for supply lines, CPVC is. Just to be clear!
I would use PEX over CPVC. PEX is capable of taking freezing temperatures without bursting, although the fittings are still susceptible to freezing. PEX can be buried for service mains, and can be used throughout the entire house as well.
You definately need to bury the water line well below the frost line!
Old 08-02-2008, 03:47 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
In South Carolina, PVC is commonly used from the curbside meter to the house. 3/4 inch PVC has more capacity than 3/4 inch PEX, if you use pex I would upsize to 1 inch.
Old 08-02-2008, 03:50 PM   #4
Rewards Points: 150
Thanks. Does the PEX need to be sleeved in conduit or ?. Ok so for a supply with PEX I need 1 inch , 3/4 is too narrow?
Old 08-02-2008, 10:03 PM   #5
Registered User
Termite's Avatar
3/4" PEX and 3/4" pipe have the same capacity. Some PEX fittings are necked down to 1/2", theoretically limiting the flow. I can tell you that I have 3/4" PEX in my house and have never had any issues with low volume or pressure.
PEX can be direct-buried.
Size is determined by the fixtures in the house. Most homes are fine with 3/4". It depends on what the demand is. When in doubt, run 1" into the house and branch off from there.
Old 08-02-2008, 10:08 PM   #6
Registered User
Termite's Avatar
Ok, I stand corrected. I've never seen that done, although it is permitted by code.
Personally, I'd wouldn't consider using a brittle material like PVC for a water line in a burial condition when other options like copper or PEX are available.
Old 08-02-2008, 11:16 PM   #7
Send a message via AIM to Marlin
I vote for copper.
Marlin is offline   Reply With Quote
Old 08-03-2008, 07:00 AM   #8
BUILDER / REMODELING CONT
buletbob's Avatar
Originally Posted by Marlin View Post
I vote for copper.
I agree but with the $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ of K copper I would use Pex.
Water Main Replacement Advice Crashless Plumbing 8 08-11-2009 06:15 AM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 12:22 AM
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 12:38 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 10:33 PM
Running Supply to Attic cibula11 HVAC 2 02-06-2007 05:08 PM
