-   -   Running new Main supply from Meter PEX or PVC? (http://www.diychatroom.com/f7/running-new-main-supply-meter-pex-pvc-24638/)
twilightcall 08-02-2008 02:49 PM
I am running a new main supply line from the meter to my house. PEX is becoming popular around here for supply lines but most still have PVC. Which would you guys use? I am making a 45 foot run with 1 90 deg. turn. I live in southern TN but it does it get cold in the winter time especially at night. Any info would be appreciated. The rest of the house is plumbed with PEX.
Termite 08-02-2008 03:47 PM
PVC isn't used for supply lines, CPVC is. Just to be clear!
I would use PEX over CPVC. PEX is capable of taking freezing temperatures without bursting, although the fittings are still susceptible to freezing. PEX can be buried for service mains, and can be used throughout the entire house as well.
You definately need to bury the water line well below the frost line!
rjniles 08-02-2008 04:47 PM
In South Carolina, PVC is commonly used from the curbside meter to the house. 3/4 inch PVC has more capacity than 3/4 inch PEX, if you use pex I would upsize to 1 inch.
twilightcall 08-02-2008 04:50 PM
Thanks. Does the PEX need to be sleeved in conduit or ?. Ok so for a supply with PEX I need 1 inch , 3/4 is too narrow?
Termite 08-02-2008 11:03 PM
3/4" PEX and 3/4" pipe have the same capacity. Some PEX fittings are necked down to 1/2", theoretically limiting the flow. I can tell you that I have 3/4" PEX in my house and have never had any issues with low volume or pressure.
PEX can be direct-buried.
Size is determined by the fixtures in the house. Most homes are fine with 3/4". It depends on what the demand is. When in doubt, run 1" into the house and branch off from there.
Termite 08-02-2008 11:08 PM
Ok, I stand corrected. I've never seen that done, although it is permitted by code.
Personally, I'd wouldn't consider using a brittle material like PVC for a water line in a burial condition when other options like copper or PEX are available.
Marlin 08-03-2008 12:16 AM
I vote for copper.
buletbob 08-03-2008 08:00 AM
Originally Posted by Marlin (Post 145377)
I vote for copper.
I agree but with the $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ of K copper I would use Pex.
